Damn problems
I don’t know how should I say it, but I’ve got a lot of bad luck with my new computer. I was happy when I eventually got it’s OS working properly, but that state didn’t last long.
When I had some problems with the GFX overheating and doing some sh*t in games I decided to download the latest VIA 4in1 Drivers and when tried to install them my computer crashed at the end of copying the files.
Since then none of games are working, there always comes out a dialog box with message:
Porsche caused an error in
Kernell32.dll
It will be closed…
I don’t want to reinstall my system , because I’ve already got bored with it:)
If anyone of you has experienced such problems and know a solution for that, please write it in this forum.
Once again I say ABIT SUCKS!
If you use an operating system with system restore you could try rolling back to a point before the installation of the new drivers. You could also try installing another set of drivers to replace the latest ones you have put on. Have you had a look on http://www.driverguide.com ???
Let us know how you get on :stick:
OK, I’ve already solved it out, the problem was in the VGA drivers.
When i down:)dated them to a moth-earlier version the problems went out.
But I’ve got some other probz.
When I’m playing games the computer automatically tunes back to windows or shows blue screens, which is pretty sh*t.
I’ll try with another drivers, maybe it’s the solution…
To be honest, games and graphics aren’t really my thing, but I’m sure someone on the forum is a hard core gamer. It might be handy if you post up your system specs and your operating system as that will help others in giving advice.:cool:
Ok, there’s no need for that.
I’ve solved this problem too.
I just installed the official nvidia drivers…
Thanks for support.
glad you got it fixed, I cant see why you did’nt try the latest offical drivers first… confused maybe? :stuck_out_tongue:
