Don’t know why, but my display driver went out of order. While normally working on the laptop it stops working. If I run a video, it just stops everything and I have to reboot first n save mode, than in the normal one.
I was searching for the driver, but could not found one. On ATI website I found ATI Catalyst drivers but I do not know whether it fits or not.
Please advice which driver can I use or helpo somehow
Well in that case it could be overheating, faulty hardware or windows corruption!
Also wouldnt be a bad idea to reinstall DirectX and do a Virus and Spyware scan!
I reinstalled the previous version of the ATI driver, and it works now, but when I turn the video on, for example a film via winamp, comp dies …
I checked on viruses, I’ll check on spyware
I’ll try to reinstall DirectX, hope that will work.
If not I think to reinstall the windows. Is that seem ok?
Well id say now that windows really hates your ATI drivers, in this case i would suggest a fresh install of windows if this is pratical!
I also recommend a registry, spyware and virus scan if you havent already!
Edit: BTW what dvd player are you using? and have you checked their website for any possible bug fixes/patches?
I’ve done all the scans …
Well I am using the DVD player which came with the laptop …
But I’ll check theirs website …
If the problem persists I’ll just reinstall windows …
