DVD RW help
how do you decide what constitutes as a good or bad DVD RW drive? should I go for lightscrbe or just standard.
That depends on the features a drive has, things you should look for are;
  • Write speed
  • Supported drive types
  • Buffersize
  • Warranty terms
  • Interface type
  • Price
LightScribe is an optical disc recording technology that utilizes specially coated recordable CD and DVD media to produce laser-etched labels. Lightscribe is one of those extra features from which you can usually beforehand say will be useful to you or not depending on your personal requirements.
Consult this link for a website with links to multiple hardware sites containing reviews about DVD drives.
Cheers,
Marcus_X
