i think you mean DVD +R/RW, DVD-R/RW, dual layer RW drives & discs are not yet available (i think) this drive is about $80 USD (well $84.2498 USD) and that drive is DVD-RAM and lightscribe, but it would be better if you had USB2, but will work with USB1.1 (just slower)
dvd RAM?? i dont know what that is an the one im buying is a a store so no shiping and i dont think im ever gona use lightscribe my friend has it and he only used it once i might get lightscrabe if they somehow com out wih color
this is the page you had a diffrent model this on if u click on the downloads page says something about win98 on the driver part it says something like this u dont need to dl drives for 2k/xp becuase it plug and play but it dosent tell u how to install driver
download this, then extract it (with winzip) then wherever you extracted it to (C:\1) use explorer and navigate to (C:\1) and double click ¨cy_ni9X.exe¨ and it will install automatically, then reboot, thats it, done.
when i clck it a hourglass comeup for just a second then nothing happenes it it supposed to open anything i rebooted and the drive is still not showing
try it another way then, dbl click ¨My Computer¨ then ¨Control Panel¨ then ¨Add Hardware¨ (i think it´s add hardware) go through wizard and select ¨Advanced¨ and just browse to folder where you extracted the zip file.
