Few Photoshop problems
On photoshop when i try to draw with a plain brush which is black it comes out grey if i go over it gets darker and darker and darker each time i do it. Ive shut it and reopened it tho and its still doin the same thing…any dieas what it could be?
Also if I try to fill my background with any colour the blank canvas ‘twitches’ and it comes up in history fil btu it is still white. Any ideas would be apreciated
Chances are for the brush problem either:
Air Brush is selected
Opacity and or fill levels aren’t 100%
The brushes blending mode isn’t “normal”
And the same for the fill - check the blending option is on Normal, not anything else.
Thanks for that waffle it was both the opacity…i shud remember to check simple things. Thanks again
