File Conversion
Last night i found a program that will convert a webpage(s) + everything in it, into a working program, so you can run for example a demo webpage as a program, without going on the internet..
but ive forgottent what it was, and my brother has cleared my history
maybe it was one of these?
http://www.aw-soft.com/
http://www.html2exe.com/
or
http://www.x2net.com/webcompiler/index.htm
Talking about Formats, I have a question too.
I usually watch DVD’s by hooking up my video card’s S-video with the T.V’s and it works fine, however, when I play real player or divx files on the PC, there is no display on the T.V. only on the Monitor.
Is this a file format problem. If it is, is there a converter program,…
thanx
