GF 9600gt ddr3 problem
Hi, this is the first my thread . I bought a GF9600gt ddr3 video card I put the card in the pci slot but i have not the Y cable for feeding the powr to the card because the cable is missing from the box .PLZ any one help , how i connect the the 6 pin with
The ATX power supply.
Hello, welcome to HWF. Unfortunately, it sounds like you will need a 6-pin PCIE connector. Either you can use an adapter than translates the 12v signal and ground from a standard 4-pin molex connector (the type CDROMs and the like use), or else you’ll need a PSU that has a PCI connector built-in.
typo correction, i think AT meant: PCIe[ot]i’ve started something now, correcting the almighty AT[/ot]
[OT]
?[/OT]
