Hardware & graphic card
Hi, I have an intel D865GLC motherboard with a cooler master 460w powersupply running windows xp home edition sp 3 32 bit and just bought an [FONT=Trebuchet]EVGA e-GeForce FX 5500 256MB DDR DVI-VGA-TV AGP Video Card 256-A8-N313-LX but for some reson when I try to install the driver its says “could not locate any driver compatibly with hardware”? Could some explain what might be the problem?[/FONT]
[FONT=Trebuchet]Thank You[/FONT]
you could try this driver..
http://www.evga.com/support/download/default.aspx
I tried it and got the same error when I download the FX series
Can you try another card … Maybe that card is no good..
I do not have any other card and just bought it on ebay lol. The graphic card has a fan on it and when i insert it into the agp slot it run. Is that any indication that it is functional ?
Could it be a compatibly issue? I did the research and I am certain the card should be compatible with the motherboard and windows xp
Is this card USED ??? Never buy computer parts off ebay…
I would test this card in a different computer to see if it is good..
I have purchase a few item on ebay and overall they all work… Anyway I dont have another pc to test it on. Thanks for the quick rely
It sounds like the video card is bad..
