HDD, PWSW LED wirings
how do i know that i already plugged the wirings on the motherboard corrctly ? is it in the motherboard’s manual?
If you haven’t plugged them in correctly then they wont work (it is possible to damage some components if you wire them incorrectly).
Yes, its in your motherboard manual!
oh, okay
thanks
