Help with cable modems plz
Will someone plz explain some things about modems to me and therefore help me shop?
For example, why is the “MOTOROLA Surfboard SB5120 38Mbps Downstream, 30Mbps Upstream Cable Modem” $72, whereas the “D-Link DCM-202 42.88Mbps Downstream,10.24Mbps Upstream High-Speed DOCSIS 2.0 Cable Modem” is only $58 AND with a $20 rebate?? Isn’t the D-Link a way better deal? Or do modems never operate at max speeds anyway?
These are the motorolla ones here
And here is the D-Link
And the motorolla one has fax, whereas D-Link doesn’t. Is that what’s causing the huge price difference? What does that mean if it has the fax feature anyway? That I can receive fax without a fax machine, as long as I have a printer?
Help will be GREATLY appreciated! Thanks in advance
Whatever you do, get a modem with an ethernet interface, not a USB one. They may seem simpler to a novice, but they’re actually more complicated.
