help with fan set up noob builder
i just purchaced an 8 fan controller
i currently have
7 120 mm fans
1 200mm fan
Cooling System: for case
Front (Intake) : 120 x 120 x 25 mm Red LED fan, 1300rpm, 17dBA (Include);
120 x 120 x 25 mm (optional) or 200 x 200 x 20 mm (optional)
Rear (Exhaust) : 120 x 120 x 25 mm TurboFan, 1000rpm, 16dBA (Include)
Top (Exhaust) : 200 x 200 x 20 mm Red LED fan, 800rpm, 15dBA (Include);
Two 120 x 120 x 25 mm (optional)
Bottom (Intake) : 120 x 120 x 25 mm (optional)
Side (Intake) : 120 x 120 x 25 mm (optional)
also i will be using a push pull setup on the cpu
any ideas or suggestions as how to set up the intake and exhaust and any clue on rpms
side fan sits right below my 560 ti video card
You have it setup optimally already. Great air flow. Generally, you want to have it set up so that air flows from the front of the case to the back. In other words, 1-2 fans placed in the front of your case should draw in air (intake) while 1-2 fans in the back of your case should dissipate air (exhaust). This dissipation should apply to any top case fans as well. Any side case fans should draw in air to keep your gpu cool.
