hey all.. turns out motherboard was faulty so i sent it back.. got another one, works perfectly.. set my brothers machine up.. installed an old ge-force2 mx 32mb (agp) installed XP on it fine.. runs dos fine..
cpu is running fine..
so’s memory..
have no errors.. but when i am trying to boot to windows.. it gets to the windows xp pro loading bar.. loads like usual.. then looks as if its going to load into windows.. but it just shows a black screen.. the monitor is on.. all hdd’s are running fine…
Was it the same motherboard (i.e. ABCmobo 123A for ABCmobo 123A)? If not, that’s the problem. Windows doesn’t like to have mobos swapped out from under it, so you can either do a repair install or reinstall Windows. I recommend the latter for less hassle in the long run.
well i built the whole machine from scratch.. including formatting the hdd.. but i will do a clean install anyway.. as its running dos.. and xp boot up fine..
