Thus I have a laptop ZET A8 laptop and worked extra, however, I broke his
hinges. I’ve disassembled the laptop and replace hinges and compiled laptop
when it burned poker like Windows Recovery, when he finished laptop is
normally turned on or do not like either one USB port and WIFI, all the
rest is operating normally, and the internet even works when you ride over
Lana. I did a new system and install all drivers again or not does not
respond, I also changed to biosu all that has to do with usb-om or in any
combination does not work. When the fallen laptop USB flash starts to shine
when it comes to loading the system stops, as well as I do that the new
system in one port lights flash or do not recognize. Light of WiFi me on
and off when pressed fn + f1 or anything in the system is not
responding. If one knows to what can be a helps. Thank you
