Just wondering, trying varius HSF’s and needing to know which one is doing the job best.
You can check in your BIOS when the computer starts up or try Speedfan
i would of thought a cpu with clock speed like that wouldent need a fan, i would of thought that they just come with large heatsinks.
well…then i have been very misinformed if that is true.
why, what have you bieng told?
its just, my 1.2ghz celeron had a crap ol fan on, and when u turned the fan compleatly off using a program, the celeron 1.2ghz never overheated
i’ve got a hella good cooling system then!
what is your cooling system?
couple of fans?
you dont need a hella good cooling system for that computer.
