HI
iam masthan from india
i hava a problem with my ide bus
i replace 14 times my harddisk bus, when i newly installed my bus then it will be working properly for 2 or 3 weeks or 2 days
after that when iam in working with some other programs then
the hardisk light will be glow for a moment and the system will be restarted
the a message is appearing at the booting time
“insert proper boot device”
after that when i install another new ide bus then the system will be working properly
what is the problem
whether smps problem or the motherboard problem or the harddisk problem i doesn’t know
please send me the reply
