Info on performance
My system is described below.
I get a score of 2888 when running 3DMark2001SE. Does anyone know if it should be higher or if it is a normal score for my system when absolutely nothing is overclocked ?
Thats pretty much normal score for a gf 2mx
look at http://www17.tomshardware.com/graphic/20020418/vgacharts-05.html they use the same cpu and videocard and almost get the same speed :wink:
If you’re running the benchmark at the default settings, that’s pretty normal. However, if you’ve lowered the color depth and/or resolution, I’d say there’s a problem.
ok thanks for the info
