I just formatted my PC yesterday, installing Win XP SP2. But the intergrated LAN card and USB is not detected in device manager. I tried HELP but cannot solve the problem.
Where did i go wrong? I am using a MSI KM4M-V motherboard.
Thanks.
Thanks.
Install the LAN and USB controller drivers with the CD you got with your mobo.
I am a little confused. After formatting and installing Windows, the hardwares who don’t have driver will be having a question mark icon in the device manager. But for my computer, no USB or LAN card is written in the device manager. How can that be?
perhaps they are disabled in the BIOS, check.
I had checked my BIOS and nothing indicated the changes of it.
My Advanced BIOS Features:
Quick Boot-enabled
virus Warning-enabled
Boot Sequence-Press Enter
CPU Internah Cache-enabled
External Cache-enabled
CPU L2 Cache-enabled
Swap Floppy-disbled
Seek Floppy-disabled
Boot Up Numlock Status-on
Typemaitc Rate Setting-disabled
Typematic Rate (Char/Sec)-6
Typematic Delay (Msec)-250
Security Option-setup
MPS Table version-1.4
HDD S.M.A.R.T Capability-disabled
My Device Manager:
Computer
Disk Drives
DVD/CD-ROM
Floppy Disk controllers
Floppy Disk Drives
IDE ATA/ATAPi controllers
Mice and other pointing devices
Monitors
Ports (COM & LPT)
Processors
SCSI and RAID controllers
Sound, video and game controllers
System devices
All these in the Device Manager and their sub menus did not indicate the existence of any USB or LAN card (although it is embedded on my MSI KM4M-V Motherboard). Can you please help again? I am rather confused.
If you didn’t install the drivers which came with your MSI driver disc, the devices may not show up in your device manager. You need to install the drivers.
