Linksys WAG200G Wireless ADSL Modem/Router
The Linksys Wireless-G ADSL Home Gateway is the all-in-one solution for Internet connectivity. The ADSL Modem function gives you a blazing fast connection to the Internet, far faster than a dial-up, and without tying up your phone line. Connect your computers to the Gateway via the built-in 4-port 10/100 Ethernet Switch to jump start your network. You can share files, printers, hard drive space and other resources. The built-in Wireless-G (802.11g) Access Point allows up to 32 wireless devices to connect to your network at a blazing 54Mbps, without running cables through the building. It’s also compatible with Wireless-B (802.11b) devices, at 11Mbps. The Gateway’s Router function ties it all together and lets your whole network share that high speed Internet connection.
  • ADSL2+ Modem, Internet-sharing Router, 4-Port Switch and Wireless-G Access Point in one box.
  • High-speed ADSL2+ Modem gives you a fast, “Always On” connection to the Internet.
  • Connect your home PCs and other wireless devices to the Gateway and the Internet using the built-in Wireless-G Access Point, or connect directly with the 4-port Ethernet Switch.
  • Advanced Firewall, Content Filtering and Security features protect your PCs, your data, and your family.
-Just one small point don’t attempt to play games on wireless it will cut off and spoil the gaming so put it in Ethernet connection and you will have super fast no problems connection when playing games. It will be fine using wireless connection for a computer/laptop to surf the net.
I highly recommend this product its well built easy to setup very fast connection. If your looking for a wireless modem then this is the one to get extremely well priced around £40-£45. I give it a 10/10 :slight_smile:
