I’m getting a new motherboard for my linux machine as the previous one died.
Just wondering if i can swap out the boards without having to re-install.
The boards use different chipsets.
Thanks.
I wouldn’t think you would have any problems, the boot scripts should load the appropriate kernel modules for your motherboard.
Thanks Addis. I’ll give it a go and see what happens.
