Hello
I have a question regarding rendering movies, when I set up batch render in to targa files.
What sort of software can I use to put those files in to the movie.
Regards
Daza
Hello
Regards
Daza
Hi,
You need some sort of compositing software to load your rendered files into which can then export them as a movie. Some of the big ones out there are Fusion by eyeon software, Adobe AFter Effects, and Nuke (made by The Foundry i think) seems to be the next up and coming big one. You would want compositing software if you want to take a 3d element you made and the put it into an existing video/plate. Video editing software may be able to do this as well, such as Adobe Premiere. I believe that newer versions of photshop can even play an image sequence as a movie too. Also, the professional version of Quicktime can import an image sequence and play it as a movie, it may be able to save it as a .mov as well, but I cant remember for sure.
