I woke up this morning and there are horizontal bars/lines flickering on my display. They seem better when the screen has a light background but are really prominant if the colors are darker. They’re even present on the bios boot screen. I tried reinstalling my graphics driver. The only thing that makes it go away is if I turn the brightness all the way up on the monitor. It sounds like a monitor problem to me but I dont have another computer to test it with. Do you think it is the graphics card or the monitor? 3D games run OK (except for the flickering). I may be able to borrow a monitor from work if you think it will help me determine the problem. Any help would be appreciated.
Your graphics card couldn’t cause such a thing mate so its definitely your monitor.
Your monitor seems to have some “complicated” pixels running along those lines.
Try out another monitor if you can and see if the problem persists. ![]()
i’ll second that
