Hello, I’m going to be building a gaming pc soon and am trying to decide what parts to put in. I am aiming to create a pc that will be able to run high-end pc games for quite a few years to come. The problem is that I know very little about mother boards any thus am in need of your assistance. Would you be able to recommend to me a motherboard that would suit my gaming needs.
Giving an extra budget on assuring that you have a good motherboard, and graphics card will suite you. Since you’re going to use your system for gaming, I suggest cutting some budget on not getting the highest CPU model, instead get the one below the fastest/latest/highest model of CPU available (preferably Intel or AMD depending on your preference and budget) then spend the cash you saved on getting a high end graphics card!
Lastly, be sure to read reviews of the hardware you’re going to buy. So as to assure yourself that people had great experiences using those hardware you picked. Some sites like Techpowerup, Tom’s Hardware, AnandTech, and Logical Increments offers such reviews.
