Motherboard Voltage Level Question.
Hello,
This is my first post here and I’m looking for some advice.I’ve used a command to display voltage levels associated with an old motherboard,the type of which is probably irrelevant.I’ve noticed that a couple of levels seem too high and have “alarm” written after them.My question is what does it mean and what should I do about it?
The output from the command is copied below.
peter@peter-G31M-ES2L ~ $ sensors
nouveau-pci-0100
Adapter: PCI adapter
temp1: +53.0°C (high = +95.0°C, hyst = +3.0°C)
(crit = +115.0°C, hyst = +5.0°C)
(emerg = +130.0°C, hyst = +10.0°C)
coretemp-isa-0000
Adapter: ISA adapter
Core 0: +40.0°C (high = +76.0°C, crit = +100.0°C)
Core 1: +40.0°C (high = +76.0°C, crit = +100.0°C)
it8718-isa-0290
in0: +1.12 V (min = +0.00 V, max = +4.08 V)
in1: +1.89 V (min = +0.00 V, max = +4.08 V)
in2: +3.33 V (min = +0.00 V, max = +4.08 V)
+5V: +3.02 V (min = +0.00 V, max = +4.08 V)
in4: +0.43 V (min = +0.00 V, max = +2.10 V)
in5: +4.08 V (min = +0.00 V, max = +4.08 V) ALARM
in6: +4.08 V (min = +0.00 V, max = +4.08 V) ALARM
in7: +3.23 V (min = +0.00 V, max = +4.08 V)
Vbat: +3.10 V
fan1: 1035 RPM (min = 0 RPM)
fan2: 2872 RPM (min = 0 RPM)
temp1: -55.0°C (low = +127.0°C, high = +127.0°C) sensor = thermistor
temp2: -2.0°C (low = +127.0°C, high = +127.0°C) sensor = thermistor
temp3: +27.0°C (low = +127.0°C, high = +127.0°C) sensor = thermal diode
cpu0_vid: +1.100 V
intrusion0: ALARM
Probably nothing. Motherboard sensors are not reliable. Use multimeter if wanna be sure about voltages.
Agreed. Motherboard sensors have never been that accurate. As Wicked said, a multimeter will be much better for readings.
