Multi WAN Load Balancer question.
I currently have a symmetrical 100mb/s fiber to the home connection and an asymmetrical 50mb/s down - 10 mb/s up cable connection, they are both connected to a Peplink Balance 380. The issue I am having is I can’t get the full downstream of 150mb/s to a single pc. I can however use two PC’s and achieve 75mb/s to each of them. According to Peplink tech support, the unit is functioning as it should. They say it can’t combine all of the bandwidth for use on a single download.
My question is, are there alternate load balance appliances such as a Fatpipe brand or other, that are capable of combining all 150mb/s into one?
10/100Mbit Nics??? in your computers? upgrade to Gigabit.
Hi, thanks for replying. I was talking about my internet connection, not my home network. my LAN is gigabit. I did find a solution to the problem though.
