i brought a pc off a friend for £65 here’s the spec:
Pentium III 450mhz
384mb SD 133 Ram
Ge-Force 2 mx400
3 month old 17" Philips Monitor
19GB IBM HDD
now everything was working fine on the pc when i got it home, windows 98 was loaded, but my friend had clearly shoved tones of shit on the pc, and it was filled to the brim with crap everywhere, so i figured right time for a clean format and reinstall of windows98
so i format: “FORMAT C: /s”
and i get: Insufficient Memory To Load Drivers or something"
so then i do: “FORMAT C:” it works.. and then i load XP but instead of installing on C: drive it creates a new partition “D:” and loads XP there, so i figure ahh well its only a server machine or whatever.. so i go into windows.. and i cant load anything because my 19GB HDD says its only 2GB!!!
WTF!? so i look at the pins on the HDD and they are correct for 16 Cylinder and 2GB+ (both C AND D read as 2GB limit), so then i go and remove D partition so i still have C left, and it still says: “no operating system found”
and i cant seem to find my HDD??
i then figured it was a naf HDD or a virus so i stick in a blank 15GB drive and it still reads as “no operating system found”
