hi. I am ok with working computers- can someone tell me how hard it is to plug a osundcard into an empty pci slot- i mean for someone who isnt sure what they are doing does it just slot in or what?
also, if my computer is under warranty- is doing this likely to void it?
id say its unlikely it’d void the warranty-read the warranty guide very carefully!
its pretty simple, just un-install your old sound card and turn off your computer,
plug in your PCI sound card into an available slot and your pretty much set!
windows will auto detect it and just follow the on-screen instructions!
i doubt it’ll void your warranty to install new hardware, all thats required to do is open the case, unscrew the pci metal piece and simply push the card into the slot, everything should adjust right, then put the screw back only this time on the pci card metal piece to secure it in place, once you boot windows it should install default drivers and you’re good to go
