I bought a Pcmcia Adapter (d-Link g dwl 650) and installed and worked fine , Then I reinstalled Windows XP from Origional Disc ,
Then when I installed the Drivers and Pcmcia card the Computer Froze ( only thing to do was remove card and Restart from On/off Button)
I have tried reinstalling Drivers from Disc, website
I tried Updating Bios ( was already updated )
I tried Updating windows
the Device manager says the Pcmcia slot is ok and Working fine .
I even took the Adapter back to the Shop and Changed it to A Netgear and same thing happened , seems to freeze on last few seconds of installation
I follow Instructions of Install , but also tried many ways , Inc uninstalling in safe mode and Reinstalling .
Computer has no Problems connecting via USB adapter or cables
So if anyone has Any Ideas would be Great
I have seen this problem all over forums and Internet but no solutions
(I am using Compaq Presario 1500 )
Thanks for help
Mark Watts
Did you tried running your computer without a modem card in it?
It’s a Laptop , So no I didn’t can you just remove the Modem card easily in a laptop or would I need to just uninstall it in Device manager ???
The wireless PCMCIA card actually was wourking for 2 weeks then I reinstalled XP Operating system from origional disc I used Before ,and the first thing I did was try the Wireless card thats when the Problem started ???
Thanks Mark
Try installing the [link=D-Link | 404]<<>>[/link] and see the manual from D Link’s website…I should have seen it by myself but my computer is restricted and I cant download anything on my computer… There are some faqs at the bottom to look out. If it doesnt solve your problem then there is a link on the right hand side to email to tech support, use that. Hopefully you will get your answer.
Thanks Mate but thats the first thing I tried , I have downloaded the new drivers from Website , and also talked to D-link myself ( as usual tech support has no Idea ) and tells you to do the stuff I had already done )
So if you have any more Ideas ??
Thanks Mark
