please help (kmenu)
i’ve been trying to edit kmenu but all atempts produce the same results, it starts starting then the window just disappears (and taskbar item disappears, with NO error messages)
tried:
right click on kmenu>menu editor
kmenu>preferences>control centre looknfeel>panels>menus>edit k menu
clicked “system” after typing “menudrake” and got error
[dave@hayes ~]$ su
Password:
[root@hayes dave]# menudrake
attribute |"true"| in "?package(mozilla-firefox)" is invalid
*** glibc detected *** free(): invalid pointer: 0x08204380 ***
clicked “root” after typing “menudrake” and got error:
Aborted
Segmentation fault
[root@hayes dave]#
[ot]i don’t know what to do - i only wanted to add opera to the kmenu[/ot]
please help !!!
EDIT: there is also a shutdow error that occures now and then (not always) and “KDEInit could not launch kontact-kmail.sh” occasionally after clicking KMail on panel
For now you can create another shortcut someplace else, such as your desktop. However, it does sound like you have a problem. Try running the following as root:update-menus -v…if there are any errors, please post them.
[QUOTE=Anti-Trend]
typed “update-menus -v” (presume command means update menus and varify)
Password:
[root@hayes dave]# update-menus -v
update-menus[4927]: Checking if urpmi is running (and waiting for it to finish if needed)
update-menus[4927]: urpmi is not locking urpmi status area, good.
update-menus[4927]: Reading installed packages list...
[root@hayes dave]# update-menus[4927]: Reading translation rules in /etc/menu-methods/translate_menus.
update-menus[4927]: Reading menu-entry files in /etc/menu/.
update-menus[4927]: 0 menu entries found (0 total).
update-menus[4927]: Reading menu-entry files in /usr/lib/menu/.
update-menus[4927]: 364 menu entries found (364 total).
update-menus[4927]: Reading menu-entry files in /usr/share/menu/.
update-menus[4927]: 364 menu entries found (728 total).
update-menus[4927]: Reading menu-entry files in /usr/share/menu/default/.
update-menus[4927]: 364 menu entries found (1092 total).
update-menus[4927]: Running menu-methods in /etc/menu-methods/.
update-menus[4927]: Running method: /etc/menu-methods/menu
update-menus[4927]: Running method: /etc/menu-methods/twm
update-menus[4927]: Running method: /etc/menu-methods/xdg-menu-spec
update-menus[4927]: Running method: /etc/menu-methods/icewm
update-menus[4927]: Running method: /etc/menu-methods/xdg-desktop-entry-spec-app
update-menus[4927]: Running method: /etc/menu-methods/xdg-desktop-entry-spec-dir
update-menus[4927]: Reading translation rules in /etc/menu-methods/simplified/tr
update-menus[4927]: Reading menu-entry files in /etc/menu/simplified/.
update-menus[4927]: 0 menu entries found (1092 total).
update-menus[4927]: Reading menu-entry files in /usr/lib/menu/simplified/.
update-menus[4927]: 78 menu entries found (1170 total).
update-menus[4927]: 78 menu entries found (1248 total).
update-menus[4927]: 442 menu entries found (1690 total).
update-menus[4927]: 442 menu entries found (2132 total).
update-menus[4927]: 442 menu entries found (2574 total).
update-menus[4927]: Running menu-methods in /etc/menu-methods/simplified/.
update-menus[4927]: Running method: /etc/menu-methods/simplified/simplified-xdg-
[root@hayes dave]#
what next ?
Looks like it worked fine. Why not try editing the menus once more?
[QUOTE=Anti-Trend]
tried typing “menudrake” and received this error, after appearing to load, loads icons, but disappears after sorting applications
[dave@hayes ~]$ menudrake attribute |"true"| in "?package(mozilla-firefox)" is invalid attribute |"true"| in "?package(mozilla-firefox)" is invalid Segmentation fault [dave@hayes ~]$
window didn’t appear “cilck root or system”
Try this thread: Segmentation Fault on DrakMenu [solved] - MandrivaUsers.org
