i have been trying to figure out how to hook up my power led to my ECS K7S5A PRO motherboard. i was told by my friend that there was a problem with the motherboard and i can not get it to work so if any one has some idea whats up with the mobo that would be kewl
spoon
Do the jumper pins on the case match up with the jumper block on the motherboard? Like a 2-pin space for it, and a 2-pin block of the LED jumper matching up?
I’ll have to check and see if I can come up with anything.
http://www.amdforums.com/showthread.php?s=&threadid=192035&highlight=K7S5A+LED
Not sure if this exactly what your problem is (it’s the non-Pro version, but the issue seems to fit yours).
Hey
sounds to me like your power LED connector is upside down or backwards…try again buddy
later
problem solved
i have solved the problem. connector had 3 prongs the wires were on the outter prongs the mobo needed on in the middle.
X___X __X_X
|X| |X| | |X|X|
|X| |X| <----- connector-----> | |X|X|
|X| |X| | |X|X|
|X|_|X| | |X|X|
| | <----pins on mobo------> | |
(mobo) (mobo)
Bad GOOD!
not working WORKING!
DAMN
damn it took off the spaces oh well thats what i get for being a n00b.
