Quick General ?
I have a question about daul monitors from one video card. If you have a VGA port and a DVI port on any one card, can you run two monitors from that card?
Thanks
The short answer is yes.
If you want to run two CRT monitors from that card, you’d need to buy a DVI-to-VGA adaptor
Thanks for the Replies! I picked up a eVGA GeForce 6600 Le 256mb for $82.
