If all the bits in the computer are working properly, but the RAM isn’t, how far into the boot sequence will it get?
Not very far … if your RAM’s faulty, it usually goes BEEEEEEEEEEEEEEP (well, for me it does!) after a couple of seconds.
try reseating the ram and reseting the cmos, hoe this helps Dave :good:
