Hi,
After hard drive failure, I have got two new Raptor HDs and a 2-ch RAID capable SATA controller. I have a few questions:
[1] My original plan was to have one disk house OS/applications, and the other as more of a data warehouse. I thought this would improve performance, i.e. if an app needs to read something off disk while it’s running, it would have a separate HD channel to record audio, for example. But what about this RAID striping thing? Would that be even better performance? Is there any way to meaningfully back up such a setup (because that is a must for this situation)? I have an external HD with Restrospect software, would that cut it?
[2] I bought some 2-fan low profile HD coolers, but they won’t fit in my case. How concerned should I be about this considering 10K drive speeds? If it really made sense, I would convert over to a case with built in cooling.
[3] I’m starting over, but had XP installed on one of the drives and was trying to get it configured… I was having problems with the OS not recognizing “new” PCI card (new hardware wizard), which was actually installed during OS install. I tried shut down->remove card->start up->shut down->install card->start up, but this didn’t work either (in fact it froze during boot whenever the hardware was removed or installed). If I remove everything non-essential before my rebuild then shut down and install it, should this take care of the problem?
I’ve been without a computer for 2 weeks, and now have all the parts I need, so any prompt advice would be veeeeeeeeeeeeeeeeeeery much appreciated!
