Restart Problem
I have been having a serious problem with my computer lately. When I am playing games for a while the computer will just suddenly restart. It has happened even with a fresh format and install on Windows 2000 and Windows XP Pro. I set windows 2000 to show me the error code with the BSOD and it came up with this…
Driver_IRQL_Not_Less_Or_Equal
STOP 0x000000D1
(0xF0000000, 0X00000002, 0X00000001, 0X85460E4F)
Now I don’t know if this is the problem it’s been having because it has only done it once and im waiting for it to happen again to verify it. But how would I go about fixing this?
also my -12v reading is at something like -167. something…is this correct? My +12V is fine and running at exactly +12V. I don’t know if this is related or not.
Any suggestions will be appreciated! :good:
My system is as follows.
SiSoftware Sandra
Processor
Model : Intel(R) Pentium(R) 4 CPU 2.80GHz
Speed : 2.84GHz
Performance Rating : PR3777 (estimated)
SMT Support : 2 Unit(s)
Type : Standard
L2 On-board Cache : 512kB ECC Synchronous, ATC, 8-way set, 64 byte line size, 2 lines per sector
Mainboard
Bus(es) : ISA AGP PCI IMB USB FireWire/1394 i2c/SMBus
MP Support : 1 CPU(s)
MP APIC : Yes
System BIOS : American Megatrends Inc. V2.0 on 07.00T
System : MICRO-STAR INC. MS-6788
Mainboard : MICRO-STAR INC. MS-6788
Total Memory : 1GB DDR-SDRAM
Chipset 1
Model : Intel Corporation 82865G/PE/P, 82848P DRAM Controller / Host-Hub Interface
Front Side Bus Speed : 4x 203MHz (812MHz data rate)
Memory Bus Speed : 2x 203MHz (406MHz data rate)
Video System
Monitor/Panel : NEC MultiSync 97F
Adapter : NVIDIA GeForce FX 5600
Physical Storage Devices
Hard Disk : Maxtor 4D040H2 (38GB)
Hard Disk : MAXTOR 6L080J4 (75GB)
Hard Disk : General Flash Disk Drive USB Device
Hard Disk : Maxtor OneTouch II USB Device
CD-ROM/DVD : LITE-ON LTR-32123S (CD 40X Rd, 32X Wr)
CD-ROM/DVD : TDK DVDRW0404N (CD 40X Rd, 16X Wr) (DVD 5X Rd, 2X Wr)
CD-ROM/DVD : AXV CD/DVD-ROM SCSI CdRom Device (CD 32X Rd) (DVD 4X Rd)
CD-ROM/DVD : Generic DVD-ROM SCSI CdRom Device (CD 32X Rd) (DVD 4X Rd)
Logical Storage Devices
Hard Disk (C:) : 75GB (56GB, 76% Free Space) (NTFS)
Storage (D:) : 38GB (35GB, 92% Free Space) (NTFS)
Removable Drive (E:) : N/A
CD-ROM/DVD (F:) : N/A
CD-ROM/DVD (G:) : N/A
CD-ROM/DVD (H:) : N/A
CD-ROM/DVD (I:) : N/A
CD-ROM/DVD (J:) : N/A
CD-ROM/DVD (K:) : N/A
CD-ROM/DVD (L:) : N/A
Storage (M:) : 279GB (216GB, 77% Free Space) (NTFS)
Peripherals
Serial/Parallel Port(s) : 1 COM / 1 LPT
USB Controller/Hub : Standard Universal PCI to USB Host Controller
USB Controller/Hub : Standard Enhanced PCI to USB Host Controller
USB Controller/Hub : USB Root Hub
USB Controller/Hub : USB 2.0 Root Hub
USB Controller/Hub : Maxtor OneTouch II
USB Controller/Hub : USB Mass Storage Device
FireWire/1394 Controller/Hub : OHCI Compliant IEEE 1394 Host Controller
Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Mouse : HID-compliant mouse
Human Interface : USB Human Interface Device
MultiMedia Device(s)
Device : Creative SB Audigy LS
Device : Creative Game Port
Printers and Faxes
Model : Adobe PDF
Power Management
AC Line Status : On-Line
Operating System(s)
Windows System : Microsoft Windows 2000 Professional (Win32 x86) 5.00.2195 (Service Pack 4)
Network Services
Adapter : Realtek RTL8139/810x Family Fast Ethernet NIC
http://memtest86.com/
download, burn and run it through atleast a full pass through each test. If you get any errors which I’m sure you will, your ram is failing.
Hmmm. I ran memtest…
When I run the memory sizing in Bios-standard mode it gives me no errors whatsoever for the whole test.
If I run the memory sizing on BIOS-ALL I get like 6 thousand errors…
I don’t understand if this means my memory is dying, cause it ran ok on standard mode..please give suggestions!
Noones got any ideas? I don’t understand what this means.
Well I guess my problem can’t be fixed if noone has any ideas…damn i’m so confused on whats wrong…
