Rocketfish 3.5 SATA enclosure Model RF-AHD35
Hi, Maybe somebody can help me on my Rocketfish 3.5 SATA HD enclosure RF-AHD35. My problem is I can’t install my Barracuda 7200 HD 120GB. Is there a SATA connector inside the enclosure? Because the one I purchased online doesn’t have any. I would appreciate if anybody can help.
Usually on enclosures like that one, the connector is built-in. In other words, you may just be able to slide in the HDD. Others use small dongles for power and data, but this is a lot less common with SATA drives, since they are designed to be hot-swappable.
