Smartlink 56k voice modem - incoming call problem
I have just purchased a new computer and have a SmartLink 56k Voice Modem onboard. I have installed the latest driver (2.91.06.374 Rel 30/09/01).
Now I am having problems with the connection. It dials up fine but then, after various degrees of time, minutes seconds or even after an hour sometime, I get the following message box appear.
YOU HAVE JUST IGNORED AN INCOMING CALL - PRESS THE OK BUTTON
This I do and then it disconnects! If I don’t press it it still disconnects!
I only use this line for my internet access so no one telephones me on this. Also my telephone does NOT have CALL WAITING.
Can anyone suggest any solution?? :confused:
Try a different driver if possible and try using your usual phone line when you normally don’t get calls and see if this crops up.
Has this happened with another modem? Can you try another 56k modem?
It’s been a long time since I’ve used dial-up, but give this stuff a shot if you haven’t already. Good luck.
You’ll probably have to enter the *## that the phone company has to disable call waiting. I know a few people who did not have the call-waiting service but on an incoming call would be disconnected and *70’ing seemed to work for them.
Hi Elaine
Try this webpage http://www.silk.net/support/callwait.htm
hope this helps, if the problem still occurs please let us know :slight_smile:
Thanks for the replies :slight_smile: Ive since got a fix patch from a person with the same problem.. have installed it and so far it seems to have fixed the incoming call pop ups!
Cool!
“So–the computer’s stupid, not you?”
Erm.. no it’s me actually :o hehehe Thanks again :slight_smile:
Oh, that line is off of SNL’s “Nick Burn’s, Your Company’s Computer Guy”. Basically, every time he’s on fixing a computer problem he’ll act like everyone should know how to fix their computer. Frequently the users/victim’s will start to say “Well, this stupid…” or “This dumb thing…” to which Nick will reply “So, the computer’s stupid not you.” I thought that was incredibly funny, so I’ve just been using it.
That long winded response is how I got that.
