is there any software that can boost the sound level withought you altering the sound level, becouse i dont have as much base on my subwoofer becouse i dont have the sound boosting capabilities with my new mobo that i did with my old mobo.
What you’re talking about is probably preamplification, and if so that would be a hardware issue more than a software one. For bass though a decent soundcard will support LFE, which sets the frequency cutoff for what is sent to the subwoofer. A higher LFE sends more frequency range to the woofer.
it just on my other mobo, i clicked this button, anf it made everyhting louder :.
darn, i will have to save up for decent sound card, any suggestions on soundcards, good ones for under £50?
Any Creative card with an EMU10k1 or EMU10k2 SPU would be a good choice. Some cards are branded “Live” or “Audigy”, yet they have cheap AC97-like SPUs – avoid those. Turtle Beach also has some pretty decent cards which are inexpensive but they lack the processing power of the EMU10k SPUs, so it really depends on what you want to do with it.
Check out the M-Audio Audiophile 2496 sound card. It’s great for creating music, playing games and listening to TV
looks good, but its a little too costly :\
[QUOTE=Anti-Trend]
Any Creative card with an EMU10k1 or EMU10k2 SPU would be a good choice. Some cards are branded “Live” or “Audigy”, yet they have cheap AC97-like SPUs – avoid those. Turtle Beach also has some pretty decent cards for inexpensive but they lack the processing power of the EMU10k SPUs, so it really depends on what you want to do with it.
Then follow Anti-Trend’s advice. Just stay away from the AC’97 codec and anything made by Realtek… or VIA. Then you will be OK ![]()
Most people end up with a Sound Blaster anyway! Although I would suggest checking out Yamaha, ESS and C-media too.
[QUOTE=jonbenge]
…C-media too.
C-Media is basically a high-end AC97, much like newer VIA or Realtek chipsets. C-media is actually the same chipset manufacturer for those fugazi Lives and Audigys I mentioned earlier – glorified AC97 with some serious driver issues. At least, all the C-Media cards I’ve encountered.
What sound card are you using Anti-trend?
Hi
I have onboard C-Media. Never again…
I am saving for a few new bits and peices and the sound card is second or third on the list.
Mine will definitly be Creative or the like.
my old 865PE DFI Infinity, had C-MEDIA intergrated, best thing about the board, and i was vv happy with the intergrated C-MEDIA, good software it seemed to be, never had drive problems too.
Point taken.
However, with up to date drivers and C-Media’s own software, my sound level and quality is just appaling. Both under Windows and Linux :ohah:
I had a PCI Creative s/c in my Dell and I was so happy with it.
Unfortunately, it was sold with the computer.
PCI, defo for me…
[QUOTE=jonbenge]
I have an Audigy 2 with an EMU10k2. Nice card, I never have problems or concerns with it. Just does what I want it to do.
Aren’t those cards more for 3D gaming and movie surround sound? How does it perform with good old fashion stereo sound?
[QUOTE=jonbenge]
Just fine. It has a great hardware EQ and digital out, so it’s pretty good for any general-purpose usage. If you just want a cheap and simple card, Turtle Beach are very inexpensive and well-built, you might go that route. But as I said earlier any card with an EMU10k chipset is an excellent choice as well.
