I have intel 4 processor with onboard ac97 sound.. windows xp home.. i had to reinstall windows and since then i cannot get sound.. i get message no hardware/software detected or something like that. I have tried all of Windows solutions. provided i did them correctly . also have updated my drivers from intel website. I dont know whats wrong …help..
What motherboard do you have?
I have an intel motherboard 865gbf
is it enabled in the bios?
I suppose so. How do I know if it is. I am really very new at all this..
Check device manager. If the driver isn’t installed, but the device is detected, you’ll see it with a yellow exclamation point there.
If you don’t have the driver CD for the motherboard check this link: http://developer.intel.com/design/motherbd/bf/bf_drive.htm#XP
yes it shows with a yellow exclam. mark.. I have already downloaded those drives etc from intel.. it still wont do sound..
I assume you installed them and then rebooted, right?
Try reinstalling them from device manager. Just right click on the device, and go to update drivers or properties…either way works, but the first option is more direct. Have it automatically find the drivers for you and see if that works. If not, you may have to direct it to the location of the driver.
Ive done that with the device manager.. and still nothing..
Have you installed your chipset drivers ?
