You can run Memtest86+ overnight and see if you get any memory errors, and at least that could narrow your problem to a hardware error. Just download the approprate binary and either burn the image to CD or to floppy respectively, boot to it and let it go for several hours. If you get even one memory error during that period, we know something is going wrong somewhere on the memory buss. If not, we can likely start troubleshooting a Windows problem.
the thing is, I’ve tried windows 2000 and xp, fresh installs multiple times and I’m still getting the same errors. I reformatted my whole system (the normal format not the quick format) so my hdd’s are fine… that eliminates that. I know it’s not software related.
[QUOTE=athomas]
Well then, do as I sugested and we can narrow the type of hardware problem from there.
Well I’m not seeing those screens anymore, just this one:
0x00000024
I looked it up on MSDN and it said to run chkdsk /r… did that, and nothing happened no errors found. It says there’s something wrong with NTFS but if I JUST installed XP how does that happen…?
[QUOTE=athomas]
…As far as I know, RAM isn’t causing this particular message.
Well you would know for sure if you had tested the RAM like I suggested. I’m trying to help you narrow the possibilities by eliminating variables; bad RAM can cause strange symptoms which are often misdiagnosed. All of the error messages you listed corroborate either bad RAM or a problem somewhere on the memory buss.
