Hi there… I’ve put together a new PC some days ago and I would like to know if my system overall temperature is safe. Here the details as Everest 2006 reports (it’s in spanish but you will find no problems reading it):
Propiedades del sensor:
Tipo de sensor Winbond W83627EHF/EHG, Fintek F75383S/384S (ISA A10h, SMBus 4Ch)
Tipo de Sensor GPU Maxim MAX6646 (NV-I2C 4Ch)
Nombre de la Placa Base MSI MS-7250 / MS-7260
Intrusión detectada en el chasis Sí
Temperaturas:
Placa base 43 °C (109 °F) MSI K9N SLI Platinum
Procesador 48 °C (118 °F) (Athlon64 X2 3600 Dual Core)
CPU Nº 1 / núcleo Nº 1 42 °C (108 °F)
CPU Nº 1 / núcleo Nº 2 38 °C (100 °F)
Aux 42 °C (108 °F)
GPU 52 °C (126 °F) MSI NX7600GT 256MB
GPU Diode 47 °C (117 °F)
GPU (ambiente) 40 °C (104 °F)
Maxtor 6L250S0 48 °C (118 °F) HD
Seagate ST340810A 46 °C (115 °F) HD
Ventiladores (fans):
Sistema 3068 RPM
Thanks in advance!
Henry :rolleyes:
