Taking a keyboard apart for a virtual reality?
Is it possible take a keyboard apart, take all the actual keys off, and put the buttons for different keys somewhere other than on the pad that is under the keys?
I started thinking about this when playing Counter-strike Source. This idea is probably crazy and nonsense but what if you could make a body suit with some keyboard keys/buttons on it, so when you hit a “key” it interacts with the game?
In CSS when you press the number 1 key, it pulls out the primary weapon (a rifle), when you press 2 it pulls out the secondary weapon (a pistol), 3 for the melee weapon (a knife), and 4 for the grenades. The keys for each weapon could positioned on your body like they are on the models in the game, so you could touch somewhere on your leg to pull out the pistol (like a holster), hit a pocket to pull out a knife, another for the grenades, and somewhere for the rifle.
As for moving, my computer chair sits on a four squared rubber mat (to protect the carpet). Could I put one “key” under each mat? When you step on one mat it presses the “forward” key, when you step on another it presses the “strafe to the left” key, and have another for “back” and another for “strafe to the right”.
Could I take the keyboard apart, and use some wire to extend the buttons to do this? Or is it a dumb nonsense idea?
It should be possible, because you just need a switch to short the specific parts of the keyboard. But with the appropriate tools you could even use a Kinect device as a controller on your computer, you can just control the game while standing :slight_smile:
