Hi I have a problem. Hope you could help!
It’s actually my machine’s problem. I bought a new system with a WD SATA 200G HD & ASUS P5GD1 motherboard. I am running win2k. Everywhere I was told that when I am using win2k without sp4 and if I have a HD larger than 137G, I will only see 137G when doing formatting. I have to install sp4, enable the large disk bit in the windows registry to see the entire disk.
Here is the problem:
When I was doing a clean install of win2k, I was able to partition and format the entire HD. Both the disk properties and disk management report single partition with 186GB. I am sure I don’t have a win2k service pack installed. I don’t see the large drive enabled in the registry. Why I am not getting the problem that everyone seems to have? Would win2k report the “wrong” size? Should I just follow the mass and split the drive into 2 smaller partitions? I am very confused!
