I own an HP Vista laptop – approx. four years old.
It is working nicely – generally. The problem I am having is with the touch pad. When I got the computer, the scale on the right of the touch pad which is supposed to work like the wheel of a mouse to scroll up and down didn’t work. Okay, I could live with that.
Actually, after I performed a restart of the whole computer from scratch – this actually began to work!
But more recently, my left click button under my touch pad stopped working. It does nothing! So I have learned to tap the touch pad. But a double click hardly ever works.
You might say, use a mouse. Well, you are right, usually the mouse works very nicely. But for some strange reason, the mouse also has a certain problem: almost always when dragging with the mouse to select some text, the selection jumps around. It will skip the first few letters and then select a few and them skip some more. Or it will take a few letters and actually move them to later on in the selection! Quite frustrating.
And now the right click under my touch pad has stopped working – more problems!
What should I do?
Avrohom
