Very Urgent Help - Suggest best wireless router
Hi,
About Me:
I am from India - Mumbai
I am planning to buy a new [FONT=inherit][U][FONT=inherit][FONT=inherit]router[/FONT][/FONT][/U][/FONT] for my home use..
My Setup/Details:
I will install this router in my living room (hall). I have 3 PCs in all in a 3000 SQ.FT. flat.
I also want to [FONT=inherit][U][FONT=inherit][FONT=inherit]access [/FONT][FONT=inherit]internet[/FONT][/FONT][/U][/FONT] from this router using my IPAD2 + Mobile. (want best wifi connectivity, long range preferred)
I have [FONT=inherit][U][FONT=inherit][FONT=inherit]internet [/FONT][FONT=inherit]access[/FONT][/FONT][/U][/FONT] via Cable LAN (2 MBPs line at present will upgrade to 8 MBPs next month) from http://www.pacenet-india.com/services.html
My Requirements:
I want to connect all my 3 PCs internally (networking) via this router.
I have a wired lan setup, so that this 3 PCs can talk to each other if they are connected to a router/switch from my living room. (I need fast file/transfer between this 3 PCs)
There are many IT geeks in my building (I want best security via this router)
None of my PCs has inbuilt WIFI (Can I get a feature in router someway which can help me connect all 3 PCs to each other wireless (without using wired cable which I am doing at present)
I want best security + best features + best future ready router (pricing is not an issue)
Please suggest me best option:
This is the best I could have found in my area/city, can you help me decide from this 4 routers.
http://www.flipkart.com/routers/compare?ids=RTRD7XKFDBPBR6CV,RTRDF2TCE9KQ84WE,RTRDF2T9HF7RNUXP,RTRD9TC4F3ZFWGMW
Rest of options available in my CITY are:
http://www.flipkart.com/computers/network-components/router-20261?ref=f11e69f9-c6eb-4225-bf88-1570a3ee4f23&_pop=brdcrumb
http://www.homeshop18.com/wireless-router/categoryid:3254/search:wireless+router/listView:false/sort:Price+High-to-Low/start:0/
http://www.primeabgb.com/index.php?orderby=product_price&DescOrderBy=DESC&Itemid=53&option=com_virtuemart&page=shop.browse&category_id=72&manufacturer_id=0&keyword=&keyword1=&keyword2=
http://www.bitfang.com/wireless-router/
If there are any other options you can suggest me depending upon my country. Please do.
Regards,
yes, in many cases this is good advice
however, ISP’s usually don’t want all their customers using the best / fastest equipment available to buy because it may show that they are the bottleneck (the slowest part of their network)
maybe you could try improving your line stats first
and you don’t mention what existing WiFi equipment you have, or whether they can be upgraded
as for my recommendation i would say the Asus RT-AC66U 802.11ac even though i haven’t read the reviews, just the specs & it also has detachable antennae (presumably also replaceable) and many additional fetchers (if you will use any of them) also would you ever be using a 3rd party firmware on it (DD-WRT, OpenWRT etc etc) ?
that’s all i can think of
Edit: what Operating System, Windows i presume (just curious)
show off
also what modem do you have ?
