Weird buzzing sound in the speakers
Hello,
this is my first post here, so if I do something wrong, please point it out. I apologise if this is in the wrong place or if it breaks any rules. This, being said, on with my problem:
I have recently bought a computer and assembled all the parts with the help of a few friends. Neither of us are professionals, but we are all studying Computer Science, so we thought it would be a good way to practice. Anyway, we had done this before, so we didn’t make any monumental mistakes. I hope.
Everything works as it should, except for the front panel audio – we couldn’t connect all the pins (to small space to get it right), so we gave up. The real problem, probably unrelated to this, follows:
My speakers (just stereo, plain, old, nothing fancy) have a weird buzzing sound when I connect them to the computer. They work fine, probably not as loud as they should. However, when I put my hand close to them, such as to change the volume, the buzzing gets louder. I can actually wave my hand towards them and hear the difference. I start noticing the buzzing get louder at probably 4 inches distance.
At first I thought it was the speakers (as I said, they are old and pretty much the chepest I could find). But when I connected them to my old computer, there was no more buzzing. This leads me to believe the problem is with the new computer, but I have no clue where to start (or even if I should attempt to fix it or take it to a professional).
I tried connecting a pair of headphones to the new computer and could hear no buzzing, but the maximum volume was way lower than the same headphones on the old computer.
Has anyone faced anythig similar? If so, what could be the cause?
Thank you in advance,
Vlad
Welcome to hardwareforums ddvlad :beer:
if you can put the sound card from your old computer in your new one try it and see if it makes a difference!
if the buzzing stops then i think its your sound card thats causing the problem
also, try your new sound card in your old computer
[OT]
I doubt this post will help you much, i’d put money on both your sound cards being part of the motherboards :stuck_out_tongue: [most are]
[/OT]
for some mobos one can get audio io only either on the back or on the front.
I have the same problem as you - the buzzing and that I get sound only on one speaker. to get output on both, I have to have the speaker plug left half-way in the socket. I don’t know exactly, but I think it happened when I was digging around in my computers guts and moved some jumpers (took them off and put them back on). maybe I had to put them exactly the way they should be cause some signal might be getting through and having crosstalk or something like that.
