What is Best Data Recovery Resources?
Hi Friends can you suggest What is Best Data Recovery Resources?
TestDisk (Win/OS X/Linux, Free): If you’re not afraid of the command line, TestDisk is an open source utility that can run against almost any platform or partition type. It does a great job of recovering data quickly, and won’t do unnecessary writes against the drive you’re trying to recover from.
One easy method is to replace damaged PCB(printed circuit board) with a matching PCB
computer peripherals online
There are a lot of data recovery tools available in the market to repair and recover lost data but currently my company used CloudBacko Software for data recovery. You can try this software once. Thanks
Now it is common for data loss of smart phones. It is importnat to looking for a good android data recovery software to avoid lossing data.
For PC or Smartphone? For Android: Android data recovery
What a great in information shared here. Thanks all.
You can still recover from android phone on computer before the deleted data overwritten by new data, an android data recovery could recover lost data from android phone without any backup file, google it to know more.
[U]http://pcsupport.about.com/od/filerecovery/tp/free-file-recovery-programs.htm[/U]
19 Free Data Recovery Software Tools
[U]http://www.easeus.com/data-recovery…re/free-hard-drive-data-recovery-software.htm[/U]
Free Hard Disk Data Recovery Software
[U]http://lifehacker.com/5237503/five-best-free-data-recovery-tools[/U]
Five Best Free Data Recovery Tools
hope this helps
falcon
You can also use Backup Bird for Linux Server Backup, Windows, Files and databases: https://www.backupbird.com
The recovery of different cellphones have different tools, such as the iPhone and Android phones belonging to different equipment, the use of natural recovery tools are also different,
For Android , the Android Data Rescuer ,and Android Data Recovery tool is be good for recovery restore lost data ,
For iPhone , the iOS Rescuer and iPhone Recovery tool can help user to get back deleted data
When you lost data on mobile phone ,you need to stop use your phone at once. Then use Samsung Data Recovery tool that is capable of recovering pictures, messages, contacts, video, audio and documents from Android smartphones including Samsung, Sony, HTC, Motorola, LG and more.
