What would be the best sound card and speakers to buy?
Hello,
I have been reading up wether its worth getting a sound card or not… I’m still not 100% sure but thought someone could help me choose one, I have a budget of around £150.00. I want the sound card to go along side some new speakers, I’ve been looking around and Corsair CA-SP211UK SP2500 Gaming 2.1 Speaker System seem to be the most appealing but if you know of something better please share :smiley:
Thanks in advance!
Hello,
IMHO best sound card in that price range would be this one:
Are you a human?
Best speakers might exceed your budget (not sure about British Pound to US$ rate):
http://www.newegg.com/Product/Product.aspx?Item=N82E16836121044
[SIZE=1]Just bought My new Horize laptop. I’m so proud of it so far.[/SIZE]
[SIZE=1]________________________________________[/SIZE]
[SIZE=1]Intel Core i7-960 3.2-3.4Ghz Processor[/SIZE]
[SIZE=1] Innovation Cooling IC Diamond 24 Carat for CPU + GPU[/SIZE]
[SIZE=1] 8GB 1333Mhz RAM (2x 4GB Configuration)[/SIZE]
[SIZE=1] 500GB 7200rpm Seagate Hard Disk[/SIZE]
[SIZE=1] nVidia Geforce GTX560M 1.5GB GDDR5[/SIZE]
Creative Sound Blaster X-Fi Titanium, Creative Sound Blaster X-Fi, Asus Xonar DX.. By order of preference, the Asus Xonar is the best sound card you can get for the buck, for me.. For the speaker, anything as long as it is 5.1 or 7.1 will do, I would recommend Logitech Z506 5.1 Speakers. You can check out other sites for more options.
