XP Serial Extraction!
Hi All:
Just wondering if anyone knew how to access your Win XP serial Code within Regedit? I know that it is accesible, however I am unsure of where to look!
Many thanks
Olly :ohah:
Right Click on ‘My Computer’ and select ‘Properties’ it is there, under where it says Registered to:
e.g.
System:
[B]Registered to:
<SERIAL CODE/REGISTRATION CODE HERE>[/B]
Computer:
<CURRENT CPU SPEED, RAM SIZE>
[COLOR=“Red”]EDIT: It’s not in regedit but it’s a way of getting your Serial Code.
All that it shows is a series of numbers! I am looking for the lettered serial code? Can this be retrieved in Regedit? and if so how?
Many thanks
Olly
[QUOTE=Olly79]
Many thanks
Olly
Just use ViewKeyXP, it’s easy to use.
ViewKeyXP.zip (8.46 KB)
You can use Magic Jelly Bean Keyfinder to find the product id.
