Hi, i was printing about 15 pictures, i belive they were tottaling in at about 39Mb, i accidently turned my server off whilst i was printing, its back on now, but i got this 15files still in the printer list in printers and faxes, i tried to cancel it but it wont, it’s not printing, it just still says deleting :s, it’s been like this for an hour, what should i do to get rid of the document?
this is a universal problem mostly involving parellel printing, its easy to fix but it involves a certain combination of sequences
your problem now lies with your printer, switch it off for about 10 seconds and then back on again (it should start printing garbled text) at this point click delete again on the pc for the print jobs then wait for another 10 seconds untill it stops printing the crap
if its still printing the crap and the jobs are still queing then press the cancel button on the printer.
if this doesnt work try resetting your pc wiv ur printer on
if all the above fails there may be a cable fault or temporary driver error
Ditto! Turn of your printer for sometime and then start again.
i did, in the end i had to turn the actual computer off.
