Dell dimension 2400, I need help...
Discussion in 'New Build / Upgrade Advice' started by Sterhelio, Aug 7, 2005.
  1. Sterhelio
    Sterhelio Geek Trainee
    the neo 2 board, the pny 6800gt, a rosewill case, and a 450 wat rosewill ps with solid reviews. I was looking at at the box on the 6800...and it said nview multiple monittor ready.....uh oh...i might be spending more money....lol what would i need for that?
  2. pelvis_3
    pelvis_3 HWF Member For Life
    That just means that its possible to connect 2 monitors to it!
    and nView is just the software that controlls it!
    nothing to worry about and
    p.s- nice stuff
    Sterhelio likes this.
  3. Sterhelio
    is it hard to configure that and would it hinder gaming at all?
  4. pelvis_3
    Its very easy to configure and its doubtful it'll hinder gaming performance!
  5. Sterhelio
    dang....there goes more money, lol.......thanks for answering all my questions. your help is apreciated alot.
  6. Big B
    I believe that multi-monitor gaming won't be as fast as it is with a single monitor. On the other hand, with a 6800GT, it might not be noticeable, depending on what resolution settings you want to run things at. The other thing is that you might run into trouble with multi-monitor support by the games. It's not been a real request, and I *don't* think it's really supported. I'm not 100% sure on that, but I remember hearing it before. I've never really looked into it.
  7. Sterhelio
    well if u couldnt dual monitor during games could i have like a media player, or web browser or stuff be up one and the game on the other? or would i have to disable to the dual monitoring when i play games?
  8. pelvis_3
    You cant have a game on one and web on the other!
    Basically just gives you more desktop space to work with!
    eg, if you have media player open and IE open you can just drag media player over to the other screen to get it out of the way!
  9. Sterhelio
    is it possible to make fullscreen games run in a window? like a program or something?
  10. pelvis_3
    Some games have an option to run in a window but not all!
