I have recently been put into a wheelchair. I am trying to deck it out with ground lights. I got sound activated lights that I want to put them on it. problem is they take a 12v Molex connection. does anyone know where to find a battery that will work with the molex connection, i am not much of an electrition. here are the lights, Newegg.com - LOGISYS Computer CLK15BL 15" Blue Deluxe Sound Activated Cold Cathode Light Kit - Case Accessories
I am not much of an electrician myself but I would try the following - Grab a 12v battery (that would have enough juice to power the light, 700ma/h I think...) and then "cannibalise" the molex connector which comes with the light. Yellow is your + (plus) and one of the blacks (or both if it makes you feel better... ) will be your - (minus).
